Hello, I have a laptop that when it starts automatically I receive a message:
IMAGE: SMART Failure
It had a Operating System and one day magically turned off and now receive that message, when I press F1 it says that it has not any Operating System. I accessed to Ubuntu Live CD to check the partitions but it has not any.
I did a check (from: Ubuntu Live CD --> Disk Utility) and I received a fail in SMART: "ID: 5 , Attribute name: Reallocated Sectors Count", here you can see it:
IMAGE: SMART Fail ID 5
Then I am thinking in download: "SeaTools for DOS", but I do not know the option that I have to select: Long test OR Full Erase OR other. I will like something like chkdsk (in Windows) that try to fix sectors and if it can not then mark them like removed (for not read/write those sectors more).
I got information from Seagate:
(From: SeaTools Support -In Spanish- --> Tutorial de Seatools para DOS -in Spanish-)
(From: SeaTools for DOS, User Guide)
NOTE: There is not any problem if I lose data, there are backups.
* Long test (Prueba larga): realiza una exploración completa de la unidad. Ésta se usa normalmente para encontrar y reparar los sectores defectuosos.
* Full Erase (Borrado completo): rellena la unidad completa con ceros. Se puede usar para recuperar sectores defectuosos y borrar todos los datos.
NOTA: No es un “Borrado seguro”.
* Long test: It will take a long time to complete. Because the "LONG Test" reads every sector on the drive, the amount of time required will depend on the speed and capacity of the disk drive. The highest capacity drives often take 6 to 8 hours to complete. At any time, feel free to Cancel the test without harming the drive. The "LONG Test" will collect information about possible defects. If any defect are found, a list will be offered at the end or after aborting the scan. You will have the opportunity to attempt to repair the problem sectors.
* Full Erase: This command writes zeros to every sector on the hard drive. This test may take
several hours to complete.
