Question Can I use the power cord from a cooler master 850v psu on a cooler master 750v psu ?
Aug 10, 2023
5
Hello, sorry to bother with this.
I need to change my 850v PSU to a 750v PSU, same cooler master, but the power cord, the plug of the 750v its EU, cant use it, so can i use the power cord of the 850v psu to power the 750v psu?
I'm having a issue with my PC, sometimes it doesn't boot, just turn on and off without booting, it doesn't finish booting, just stay in that loop on and off, so to rule out the psu I need to switch to the other psu, to see if that was causing the issue. I got the 750 as replacement and I can't send it back
Short answer... no.
One should use only the cables that come with a psu.
Nobody can tell you if there are significant or dangerous differences.
Yes, it is a pain to remove and replace the psu cables.
Oh yeah, I have to remove all the cables that goes to the motherboard, not a problem with that. I was asking for power cord of 750 psu, because the plug it's EU, I can't use it here, so the one I can use it's the power cord of the 850 psu, but not sure if it would be ok, save to use it
