R rakinb Reputable Aug 12, 2014 18 0 4,510 Aug 13, 2014 #1 I know I should buy a different CPU fan for overclocking, but how many amps should I have for overclocking my amd fx-6350 and my XFX Radeon R9 270, and could I overclock both at the same time?
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,751 1,835 159,590 Aug 13, 2014 Solution #2 A XFX 550w would be a better fit. Upvote 0 Downvote Solution
R rakinb Reputable Aug 12, 2014 18 0 4,510 Aug 13, 2014 #3 A XFX 550w would be a better fit. So how many amps on the 12V should I have at minimum Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,751 1,835 159,590 Aug 13, 2014 #4 24 amps Look for a EVGA 500B Upvote 0 Downvote
R rakinb Reputable Aug 12, 2014 18 0 4,510 Aug 13, 2014 #5 24 amps Look for a EVGA 500B So I can overclock my amd fx-6350 and r9 270 with 30 amps or is that not enough? Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,751 1,835 159,590 Aug 13, 2014 #6 If you want to overclock get a quality PSU from SEASONIC. Upvote 0 Downvote
R rakinb Reputable Aug 12, 2014 18 0 4,510 Aug 13, 2014 #7 If you want to overclock get a quality PSU from SEASONIC. What about corsair or rosewill Upvote 0 Downvote
Dark Lord of Tech Retired Moderator Aug 18, 2009 128,751 1,835 159,590 Aug 13, 2014 #8 Corsair HX and AX series and Rosewill Hive and Capstone are ok. Upvote 0 Downvote
R rakinb Reputable Aug 12, 2014 18 0 4,510 Aug 13, 2014 #9 Corsair HX and AX series and Rosewill Hive and Capstone are ok. So the XFX 550, EVGA 500B, Corsair AX or HX are ok for overclocking both my video card and cpu? (sorry for so many questions, last one to be sure lol) Upvote 0 Downvote
