Hi guys,
So I'm currently running four Noctua NF A14 ippc3000 fans in my case.
All of these fans are pwm fans and they are connected directly to the motherboard's 4-pin fan headers.
The motherboard I'm using is MSI Z370 A-pro.
So Noctua indicates that this particular type of fan has a minimum speed of 800 rpm (+/- 20%), which is a lot lower than 40% of the fan's maximum speed (3000 rpm).
My question is: is my motherboard able to set these fans to run below 40% (or even 30%) of their speed?
(P/S: I'm asking because I read somewhere that some motherboards' pwm control will not allow fans to run below 40% or 50%. I'm not sure if this is right. But if this is the case, then setting my fans to run at 30% of their speed will cause any danger to the fan itself or to the motherboard?)
