[SOLVED] Can my 600BQ Power Supply work with this RTX 2070 Super
Sep 21, 2020
17
Hi I'm thinking of buying the EVGA RTX 2070 Super Black Edition 8GB but it says on the min requirements for a power supply that you need 650W, I have a EVGA 600BQ Power Supply would that still be enough?
Here are my specs:
CPU: Ryzen 5 2600
Motherboard: Asrock B450m Pro4
Ram: 16GB Ram
power supply: EVGA 600BQ
Sep 21, 2020
17
Phaaze88
Ambassador
It might. It might not.
Wattage isn't everything. The quality of the internal components matters more, and that's where your current psu falls behind on.
A low quality psu paired with a mid-high end gpu isn't exactly a stellar combination.
Karadjgne
Ambassador
Not a problem. Your whole pc won't be pulling more than @ 400W (ish), well under what that BQ is capable of sustaining.
They are sorta correct, the BQ I believe is the one 'B' Evga that's not halfway bad, so there's that at least. It's the other 'B' units that really do not belong in a gaming oriented pc.
I have a full custom loop, 3700x with OC, 2070S run by a 600w Corsair SFX (stack a couple of cigarette packs together and the size is close).
