can my build fit my case?
Muath_
305
So im building my new pc from my old case. will these fit in it?
Motherboard- Gigabyte AMD FM2+ A68H SATA 6Gb/s USB 3.0 mATX ATX DDR3 2133 NA Motherboards GA-F2A68HM-H
GPU- GTX 750ti SC
CPU- athlon x4 860k
RAM- single 1x8gb crucial ballistix
PSU- EVGA 600 B1 80+ BRONZE, 600W
HDD- 500GB
my case model- HP case product number XZ776UT#ABA. i think its a 500B microtower
if not could you recommend me a case for under $30
video card is small, so is the motherboard.
odds are in your favor, but HP does make proprietary components and there are no guarantees. I guess only way to find out is to try it, or hope that someone else on this forum has managed to fit the same equipment in the same tower. (very unlikely)
there is a huge selection of Mid Towers on amazon, any standard Mid Tower will work.
