Hello guys,
I will be building a gaming computer and wanted to know if it was possible to get the chassis that I have chosen to control more then 4 fans.
This is the case I will be getting:
http://www.newegg.ca/Product/Product.aspx?Item=N82E16811139005
I know there is one in the front and top so that is 2 down. The left side panel comes with glass or a mesh, I would like to use the mesh and get 4 120mm fans in there but control all of them.
I would appreciate your opinions also if you think it is a good idea or not worth it.
Thanks guys, Vanmarq
