B bestie0419 Oct 23, 2018 2 0 10 Oct 23, 2018 #1 so my GPU supports a hdmi 2.0b , My monitor is a VGA Monitor, can it connect using converter vga to hdmi ? (Sorry for bad English)
Solution Glenwing Oct 23, 2018 No, a VGA to HDMI converter is for connecting a VGA computer to an HDMI display. You need to use an HDMI to VGA converter.
Glenwing Splendid Aug 8, 2015 3,206 349 25,990 Oct 23, 2018 Solution #2 No, a VGA to HDMI converter is for connecting a VGA computer to an HDMI display. You need to use an HDMI to VGA converter. Upvote 0 Downvote Solution
B bestie0419 Oct 23, 2018 2 0 10 Oct 23, 2018 #3 Ahh. If my monitor is just a regular hdmi. And the VGA computer has hdmi 2.0b , can i connect it with hdmi to hdmi cable? Upvote 0 Downvote
Glenwing Splendid Aug 8, 2015 3,206 349 25,990 Oct 23, 2018 #4 If your computer has HDMI and your monitor has HDMI, then yes you can connect them with an HDMI cable. All versions of HDMI are intercompatible. Upvote 0 Downvote
das_stig Glorious Jul 24, 2009 8,626 218 46,390 Oct 23, 2018 #5 Unless you have one of the latest monitors, it probably a HDMI 1.2/1.3/1.4 port, so a standard HDMI 1.4 cable off Amazon etc would be suitable. Upvote 0 Downvote
