Hello,
I've read somewhere that old monitors can cause FPS drops, I use 2 Monitors and I was thinking of upgrading one of them (The main one that i use for gaming), but I've got few questions:
My Specs:
Currently the LG M227WA is using RGB with an adapter to convert it to DP to be used on the RTX 3070, and the other monitor is connected by HDMI directly.
Any advices If I should upgrade one, both, none or what I can get away with?
Thank you
- If I Upgrade 1 monitor, how would it work with an older one?
- Does it affect FPS at all?
- Do I need a new monitor with my current pc build setup as I'm still on 60Hz or is it fine to skip?
- LG Electronics M227WA - https://www.lg.com/ph/monitors/lg-M227WA-monitor (60 Hz)
- LG Electronics LG IPS FULLHD - https://www.lg.com/africa/monitors/lg-22MP55HQ-P (60Hz)
M227WA (1920x1080@59Hz)
LG IPS FULLHD (1920x1080@60Hz)
My Specs:
CPU: Intel Core i7-10700 (Comet Lake-S, Q0)2900 MHz (29.00x100.0) @ 4587 MHz (46.00x99.7)
Graphics: Zotac RTX 3070 NVIDIA GeForce RTX 3070, 8191 MB GDDR6 SDRAM
Motherboard: GIGABYTE H410M S2H
BIOS: F3, 08/28/2020
Memory: 32768 MBytes @ 1196 MHz, 17-17-17-39
- 16384 MB PC19200 DDR4 SDRAM - Kingston KHX3200C16D4/16GX
Drive: Patriot P210 1TB, 1000.2 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: KINGSTON SA2000M81000G, 976.8 GB, NVMe
Drive: WDC WD20NMVW-11EDZS7, 1953.5 GB, Serial ATA 3Gb/s @ 3Gb/s <-> USB
Drive: ST1000LM024 HN-M101MBB, 976.8 GB, Serial ATA 3Gb/s @ 3Gb/s <-> USB
OS: Microsoft Windows 10 Professional (x64) Build 18363.1256 (1909/November 2019 Update)
Thank you
