So I have an i3. A standard chassis. And I want to upgrade my gpu to gtx 970. Don't worry about the i3, I will upgrade it later to i5 or i7. The problem is that can the gtx 970 run on this psu?
http://www.xigmatek.com/product.php?productid=165&type=specification
I sure hope it does because i want to buy a better chassis with the extra money I will be left over with after I buy the GTX 970. And my second question is will water cooling be required for this gpu if I have no intentions of overclocking? Thanks
