I ask because I am considering using a 65w usb-c charger with this laptop instead of the original Razer 100w charger when travelling and I want to know if that will limit what I can do on the laptop? In particular, will 4k video editing be hampered or even be impossible?
My laptop is a Razer Blade Stealth 13 (Early 2020) - RZ09-0310
The original PSU is a USB-C Razer 100w RC30-0310, which outputs at 5v 3a, 9v 3a, 15v 3a, 20v 5a.
Why does it output at 4 different voltages and which voltage is used for charging the battery?
This is a 100w charger, most usb-c chargeers for small laptops are 65w so why is this Razer charger more powerful?
Is the extra power (100w as opposed to 65w) to charge the battery faster or are there some resource intensive taks on the laptop, such as high frame rate gaming, or 4k video editing, that require the psu to be outputting at 100w?
Would a generic usb-c charger that can only provide 65w maximum provide the laptop with suffcient power under all circumstances?
It has been my experience over the years with using laptops that the most resource-intensive processing cannot be done on battery but requires the psu to be connected to the machine, though I have never seen anything posted on the net to corroborate this.
I have looked on the internet to try to understand USB-C power delivery but stil haven't found anything to answer my questions.
Your insight is appreciated.
