G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
Kindly folks,
I have installed this new ATI video card in 2 different MoBos: an ABit (KT7,
I think) with 2Ghz Celeron, and an ASUS-A7V with 800MHz AMD Athlon; and can
not get it to let me enable the TV-out feature. I have tried resolutions
from 640x480 through 1024x768 with all combinations of colors and clicked
"Apply" each time I made a change without success. Forcing a refresh rate
of 60Hz does not seem to help either. There is always a red X over the
connector where I should be able to enable the TV-output. I only had 1
ordinary VGA monitor connected to the card at the time. The DVI connector
is not being used at all.
I did briefly install it in an old test PC (233 MHz Pentium) and was able to
enable the TV-out feature. However, when I connected the TV-out jack to a
VCR, I was unable to record anything - I suspect due to the ancient BIOS in
that Mobo.
I checked the archives, but could not find anyone else with this problem.
Thanks for any advice,
Charlie Carothers
To email me, eradicate obfuscate and remove .invalid
Kindly folks,
that Mobo.
Charlie Carothers
