Can not use full memory
Screenshot - Imgur
Hi, I hope you can help
My eldest son and I built a PC for my youngest in December 2021. When we did it was only showing as running 8GB of the 16GB installed (Crucial Ballistix RGB 16GB (2x 8GB) 3200MHz DDR4 RAM). They were bought as a pair. We did try to fix it at the time but came up with no solutions and assumed either a) it was just a display issue or b) he wouldn’t even noticed.
To skip the below, it’s possibly the BIOS Update but before I do that I would like to rule out the graphics card (Nvidia P620) which I think is the culprit.
Fast forward to 2023 and he can’t play the current EA24 without issues. The issue is the memory and:
What I have tried before realising it’s a reserved issue
Screenshot - Imgur
- Windows is showing 16GB installed
- BIOS is showing 16GB installed
- Only 8GB used
- Running with either slot with just 8B
- Both sticks separately
- Swapping the 2*8GB
- https://www.partitionwizard.com/clone-disk/hardware-reserved-memory-windows-10.html (except Update BIOS)
- Change maximum memory in System configuration
- Changed virtual memory settings
- Updated windows
- Restored BIOS to default (we had played with settings in a failed attempt to install Windows 11)
- Updated drivers
- Swapped the memory sticks with the working Corsair Vengeance LPX 16GB (2x 8GB) 3200MHz DDR4 from my system.
- updated BIOS
- solved the issue
