Guys help. This is the first time I bought a can of compressed air to clean my pc components, but sadly there is water inside! How do I get rid of all the water in it? Is this normal? WTF... I don't want to spray water on my rig.
What the! Really? SO THIS IS NORMAL?? HAHA Sorry, this is really my 1st can of compressed air. So how do I spray my MOBO with it...? I am so afraid to spray it on the mobo, gpu and ram slots....... A little bit of moisture, then boom burn. Well unless I dry it first of course, but I don't want rust.
BTW, I tried spraying it randomly on an upright position, it still sprays water... It sprays just a little bit, but that's what it takes to ruin my rig too..
If you spray it out and let one of the drops land you will see that it will quickly evaporate. It isn't like you are spraying water, you are actually spraying a chemical out of the can. This will evaporate quite quickly as it turns to a gas by boiling off in normal room temps.
