ive always thought that having the
Maximum Processor State(A advanced power option for windows)
all the way up was good for speed
so i kept it at 100
well can having that setting lower like 50
help the CPU stay cooler?
this is a desktop if that makes a difference.
im trying to figure out how to keep my computer down to 30-40 degrees.....
it seems if my cpu usage is even at 50% it gets the CPU up to the 50's in temps(C)
btw is it true that the fx4100(FX series) AMD (CPU)
has a 20 degrees offset?
i got this information from coretemp's faq page(a program to read my CPU temp)
if so that is the temp im going by atm.
or can bad thermal paste placement cause heat to rise? bc i read that if you put to much it would
so i kept it at 100
