Hello,
Can someone help me figure out if this is possible? I wasn't sure where to put this question. I hope I'm right here.
I am strongly convinced that the backlight modulation by the PWM of LCDs is having a bad effect on my health (I don't want do go into detail). Therefore, I'd like to know if it is possible to remove the PWM from an LED backlit LCD physically and have no subliminal flicker and the monitor still working afterwards.
I have heard that some LEDs disable the PWM automaticly at a full brightness setting but I don't want to risk buying one that would flicker at full brightness. I am aware that the LCD would loose its dimming abilities, be brighter, consume more electricity, have a shorter lifetime etc. The only thing that matters to me is to have the flicker removed and the display showing a picture after the removal of the PWM. By flicker I mean every form of it that is visible or invisible to man.
Whould people that repair electronic devices such as monitors be able to remove the PWM and connect the LEDs where the PWM was previously connected? Or would they not know what a PWM is? I'm not planning on doing this myself.
Is there only one PWM that needs to be disabled or disconnected are are there loads of them in LED backlit LCDs? I am not interested in doing this with CCFLs.
Thank you for any helpful answers. It would really mean a lot to me if this was possible.
