Can sata hdd be on same power cable as optical drive?
distracted7
I have a custom build and while everything is up and running, I am wondering if it is OK to have your HDD and an optical drive on the same power cable?
I have two HDD's and two DVD drives. The main HDD and main DVD writer/burner are on the same power cable. I have a 850 watt PS. When I burn a disk, my computer flips out and runs really slow...basically starts doing weird stuff. Is this because of the two being on the same power cable?
Thanks for any input!!
Beth
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
ASUS P5WDG2-WS PRO LGA 775 Intel
Intel Core 2 Quad Q9450 Yorkfield 2.66GHz 12MB L2 Cache LGA 775 95W Quad-Core Processor
Thermalake 850 watt Power Supply
Western Digital VelociRaptor WD3000GLFS 300GB 10000 RPM 16MB Cache SATA (main)
Western Digital Raptor WD1500ADFD 150GB 10000 RPM 16MB Cache SATA (scratch disc)
CORSAIR 8GB (4 x 2GB) 240-Pin DDR2 SDRAM DDR2 800
BFG GeForce GTS 250 OC graphics card 1GB GDDR3
LITE-ON 20X DVD+R 8X DVD+RW 8X DVD+R DL 20X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner with LightScribe
LITE-ON 16X DVD-ROM 48X CD-ROM SATA DVD-ROM
Sorry, I didn't mean to be vague. It basically comes to a stand still. It is slow...almost to the point of shut down. If I try and click on a program, it certainly won't load it. If I already have a program open, such as CS4 and or Bridge, it is unusable, won't load images. This only happens when using the DVD multi drive. Also, many times the drive won't open when I try to use it. And it seems to have a high refusal rate of DVD's that I try to format/burn. It will say that it is unable to format disc. Could the drive simply be bad?
