Can Seasonic S12II 620W 80PLUS Bronze power my PC?
chaozzs29
14
Hi, good day guys I need some advise because I have Seasonic S12II 620W 80PLUS Bronze power supply 4 months old, is this power supply enough to power my rig? or should I get a new one with higher wattage?
My computer specs:
CPU: AMD Ryzen 5 1600x
GPU: MSI GTX 1070
RAM: 2x 8gb Gskill Trident Z RGB 2400
Board: MSI B350 Tomahawk
SSD: Samsung 850 evo 250gb
HDD: Western Digital Caviar Blue 1TB
Fan: 4x Corsair 120mm Red led fan and Thermaltake Riing 12 RGB 120mm 3 Pack
CPU Cooler: MSI Core Frozr L 120mm
Case: Inwin 303
PSU: Seasonic S12II 620W 80PLUS Bronze
Any advise will be much appreciated thank you.
Yes, it is a pretty good unit and the wattage is more than enough. That setup wont draw more than 500w max from the wall even after overclocking, so you should have more than 100w of headroom. You should be good.
Ideally here is how it should be connected. You only have one PCIe cable......
NOT THIS WAY>
