Can someone check if all these parts will work and be functional??
Jul 3, 2018
13
I am a first time PC builder and trying to make the budget in 1000-1500$ with rgb functionalities. Thermaltake RGB fans and water cooler would hope to be controlled by one button. I wonder if any other parts will fit the case and function as it is supposed to be.
Heres the part list that I created : https://pcpartpicker.com/list/FTJfmq
1000-1500$ Range
Made a change to your CPU and Motherboard, at this point you really should get a Ryzen 2nd gen CPU. They also are far less picky about memeory speed so you could drop down to 2666mhz RAM and offer better single core performance. The Mobo is the older 1st Gen ryzen but ASRock has been good about updating the BIOS shipped with their boards so chances are you wont have an issue. If you do AMD will send you a BIOS upgrade kit.
I'm not super familiar with Thermallake PSUs, but if it were me I would get either a EVGA G2/3 or a Seasonic Focus Plus 550-650 watt.
PCPartPicker part list: https://pcpartpicker.com/list/TpGPzY
Price breakdown by merchant: https://pcpartpicker.com/list/TpGPzY/by_merchant/
CPU: AMD - Ryzen 5 2600 3.4GHz 6-Core Processor ($185.00 @ Amazon)
CPU Cooler: Thermaltake - Water 3.0 Riing RGB 360 40.6 CFM Liquid CPU Cooler ($139.99 @ Newegg Marketplace)
Motherboard: ASRock - AB350 Pro4 ATX AM4 Motherboard ($73.98 @ Newegg)
Memory: G.Skill - Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory ($179.99 @ Newegg Business)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($43.90 @ OutletPC)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card ($299.99 @ Amazon)
Case: Thermaltake - View 32 RGB TG ATX Mid Tower Case ($129.99 @ Newegg)
Power Supply: Thermaltake - Toughpower Grand RGB 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($81.99 @ SuperBiiz)
Wireless Network Adapter: Gigabyte - GC-WB867D-I PCI-Express x1 802.11a/b/g/n/ac Wi-Fi Adapter ($33.89 @ OutletPC)
Monitor: AOC - G2260VWQ6 21.5" 1920x1080 75Hz Monitor ($100.54 @ Walmart)
Keyboard: Corsair - K95 RGB PLATINUM Wired Gaming Keyboard ($169.99 @ Amazon)
Total: $1439.25
Generated by PCPartPicker 2018-07-03 18:08 EDT-0400
Jul 3, 2018
13
Oh thank you~
Also, it says theres issue on the watercooler not fitting the motherboard. If i move he fans to the top and put radiator on front, would that still work?
Apr 30, 2018
22
4
I would recommend not putting your radiator in the front, as your radiator is meant to deal with hot air. Cold air coming in the front, hot air going out the back.
