Question Can someone check if these parts are compatible
Jun 9, 2021
47
I would recommend getting Crucial Ballistix ram it’s cheaper and has 3600 MHz at c16. Also If you want rgb you can get the rgb version. Also if you are getting a 60 inch tv make sure your not to close to it. I recommend some blue glasses. There pretty cheap and you can get them with your prescription. Here are the links;
https://www.newegg.com/ballistix-32gb-288-pin-ddr4-sdram/p/N82E16820164206?item=N82E16820164206&source=googleshopping&nm_mc=knc-googleadwords-mobile&cm_mmc=knc-googleadwords-mobile-_-pla-_-memory+(desktop+memory)-_-N82E16820164206&gclid=EAIaIQobChMIkbjf74D38QIV6h-tBh17Hw_cEAQYASABEgLwIvD_BwE&gclsrc=aw.ds
https://www.amazon.com/dp/B00BQ7KBV4?tag=dotdashvhealt-20&linkCode=ogi&th=1&psc=1&ascsubtag=4579815|n726bae93e15f4cc2b79673acf994b27f15
Reactions: helper800
helper800
Ok nice and this is not a gaming build its a programming build actually :)
For a programming build you are spending a lot on its aesthetics. You can make a build that performs exactly the same but costs significantly less if you focus less on the RGB and more on price to performance parts. I felt like it would be a bit of a disservice to not at least mention this to you and provide an alternative. The 5600x has nearly the same multi-core performance as the 3700x but is around 20% faster single core performance while using less power, is easier to cool, and being cheaper.
We are looking at a 300 dollar difference between the builds with better single core performance and similar multi-core the only difference being aesthetic and a slightly lower wattage PSU. If you are worried about going from 8 to 6 cores then spend those savings on a 5800x or 5900x.
PCPartPicker Part List
CPU: AMD Ryzen 5 5600X 3.7 GHz 6-Core Processor ($349.99 @ Newegg Canada)
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler ($144.72 @ Amazon Canada)
Motherboard: Asus ROG STRIX B550-F GAMING (WI-FI) ATX AM4 Motherboard ($219.50 @ Vuugo)
Memory: Crucial Ballistix 32 GB (2 x 16 GB) DDR4-3600 CL16 Memory ($227.50 @ Vuugo)
Storage: HP EX950 1 TB M.2-2280 NVME Solid State Drive ($139.88 @ Canada Computers)
Video Card: Zotac GeForce RTX 3060 Ti 8 GB Twin Edge OC Video Card
Case: Lian Li Lancool II Mesh ATX Mid Tower Case ($139.99 @ Canada Computers)
Power Supply: SeaSonic FOCUS 750 W 80+ Gold Certified Semi-modular ATX Power Supply ($105.99 @ PC-Canada)
Monitor: Asus ROG Swift PG65UQ 64.5" 3840x2160 144 Hz Monitor
Total: $1327.57
Generated by PCPartPicker 2021-07-22 12:12 EDT-0400
Reactions: YoIAmDashing
Jun 9, 2021
47
SevacSingh The monitor you chose is quite expensive and the 3060ti won’t be able to get 144hz at 4K in most modern day games so you may want to downgrade the monitor.
ocer9999
Intel Flavor, 8 core with decent IPC on single core:
CPU: Intel Core i7-10700F 2.9 GHz 8-Core Processor ($339.00 @ Canada Computers)
CPU Cooler: ARCTIC Liquid Freezer II 280 72.8 CFM Liquid CPU Cooler ($143.44 @ Amazon Canada)
Motherboard: ASRock H570 Steel Legend ATX LGA1200 Motherboard ($160.60 @ Newegg Canada)
Total: $1256.40
Generated by PCPartPicker 2021-07-23 10:06 EDT-0400
Jun 9, 2021
47
Yes King Dranzer is right the cheapest I could find that monitor was 4.5k USD which is at least 3 times as much as your build and you won’t be able to even reach 4K 144hz. If you want 4K you might want to look into a monitor like the Asus TUF Gaming VG289Q it’s 4K 60hz 1ms. You might want to do 1080p gaming as well here is a good monitor for that is the AW2521HFL it has 240hz 1080p 1ms.
