Can someone go over my bulid and give me advice?
Zubj
This is my first time building a CPu an i would like feedback on my choices
CPU=AMD FX-6300 3.5GHz 6-Core Processor
GPU=Sapphire Radeon R7 260X 2GB Video Card
RAM=Team Elite 8GB (1 x 8GB) DDR3-1600 Memory
MotherBoard=ASRock 970 Pro3 R2.0 ATX AM3+ Motherboard
Case=Enermax ECA3290A-G ATX Mid Tower Case
PSU= Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply
budgets is 600 dollars
If it is for gaming i would go with i3 4160
change your GPU for GTX 750/Ti
get 2x 4gb ram for dual channel
change you motherboard to B85 with all connectors that you need
you dont need 600w for this PC 400w will be fine and get better quality PSU than CX series. Tier 1 and 2 are quality PSUs http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
You can aslo tell us your budget. its hard to suggest parts when you dont know the budget
is this over budget?
CPU: Intel Pentium G3258 3.2GHz Dual-Core Processor ($64.98 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.89 @ OutletPC)
Motherboard: ASRock H97M Anniversary Micro ATX LGA1150 Motherboard ($68.98 @ OutletPC)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($54.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: Sapphire Radeon R9 280 3GB Dual-X Video Card ($190.98 @ Newegg)
Case: Raidmax Hybodus MicroATX Mini Tower Case ($46.98 @ Newegg)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($51.98 @ Newegg)
Total: $547.27
Generated by PCPartPicker 2015-04-29 10:29 EDT-0400
