Can someone help me build a pc
toot12311
658
Just send me the parts link ill tell you what I want im on a budget and im also not looking to play new games or anything just looking to play LoL on max and Counter Strike GO at higest Res but lowest settings
I would like Quad Core CPU but everything else is your choice also need Win 7 OS
just send me a link if anyone can do that with all the parts. No more than 510$
Hello Toot12311, I am fairly good at building PC's and I can definitely build a very good gaming PC for you with that budget. I have some questions though. Do you want a dvd drive? or can you do everything by USB?
depends how do you install windows without it thats the only reason i would need one. but yea you can throw one in there if its around the price range
A typical DVD drive is about 20-30 dollars
Ok I have a few of the parts picked out but from personal experience, can you hook your pc right into internet through cable or do you want a wifi card for your build?
no wifi do not need that
Do you have a mouse, keyboard, and monitor?
yes i have everything even monitor.
Nice, my friend....here you go http://Go to that website and all your parts will be there, even your OS
You might want to check in with some more people just to make sure this is a good build.
Try this:
CPU: AMD FX-4300 3.8GHz Quad-Core Processor ($79.20 @ SuperBiiz)
Motherboard: MSI 760GM-P23 (FX) Micro ATX AM3+ Motherboard ($44.99 @ Amazon)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($38.40 @ Amazon)
Video Card: Zotac GeForce GTX 750 1GB Video Card ($97.98 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($26.99 @ Newegg)
Power Supply: Corsair Builder 500W 80+ Bronze Certified ATX Power Supply ($49.99 @ NCIX US)
Optical Drive: LG GH24NSC0B DVD/CD Writer ($9.99 @ Newegg)
Operating System: Microsoft Windows 7 Professional SP1 OEM (64-bit) ($130.00 @ Newegg)
Total: $527.53
Generated by PCPartPicker 2015-06-01 04:21 EDT-0400
is a cpu cooler not necessary?
