Build Advice can someone help me build a system?
rodz221
BANNED
Apr 26, 2020
hi i am looking at buying AMD Ryzen 5 3600 but i need some advice on Motheboard.
i seen a bundle with ryzen 3600 plus ASUS PRIME B450M-K M-ATX Motheboard. is that compatible right away with out doing a bios update. also is it worth getting DDR4 3200MHz or is 3000MHz good enough and save the few extra $$ oh also is a 480wat psu enough. thanks for any replies
kanewolf
The power supply question depends on the graphics card you are using. A Ryzen 3600 requires a separate graphics card.
The motherboard BIOS might depend on where you purchase. Some retailers that offer bundles, guarantee compatibility.
rodz221
BANNED
Apr 26, 2020
i think i found a better deal for my needs.AMD Ryzen 5 1600 AF, MSI B450M MORTAR MAX Motherboard, Corsair Vengeance LPX 16GB (2x8GB) 3000MHz DDR4
cpu isnt as good but is about $200 cheaper due to including ram. the reviews ive watched on the Ryzen 5 1600 AF look ok
i guess my next question is can i overcock on a MSI B450M MORTAR MAX Motherboard
