Can someone help me choose a good monitor?
Andrew_118
Commendable
Apr 21, 2016
14
https://pcpartpicker.com/list/WZjh4C
That is the build and i was wondering can someone find me a monitor that is a good monitor for this build that will give me the max quality that i can get with the 1080 ti and the i7 8700k without bottlenecking? I was also wondering can someone review this build and see if it is a good build? I have the money for it i just want to know if all these parts will go together good.
Free-Sync is AMD only. You need a g-sync card.
The best one I think is this:
https://www.newegg.com/Product/Product.aspx?Item=N82E16824025836
I prefer this to 4k screens. This one is 2560x1440 at 144hz and with G-Sync and it is a very high quality panel as well.
But it costs $850.- There is nothing else like it out...
Hey, actually this is a pretty solid build. The 1080 ti should complement the i7 nicely. If i may ask, what is your budget and I’m guessing you’ll be using your 1080 ti for resolutions higher than 2k??
But it costs $850.- There is nothing else like it out there.
If you can live with 60hz (in which case you won't need g-sync on a 1440p monitor with your very high end build).
Then this monitor is functionally the same and only $310
https://www.amazon.com/Philips-BDM3270QP2-LED-Lit-monitor-2560x1440/dp/B01LXPX9I4/
