Can someone help me figure out how to change volume on my monitor...
thomas1234
6
I have an AOC E2752Vh. I only use it on its HDMI input, so I can play Xbox One on it. However, I can't figure out how to turn my volume down/up. For example, hitting the + and - buttons on the bottom of the monitor won't change anything.
To turn down the volume you must press the right angle chevron (>) first. This brings up the volume menu. This is counter-intuitive because you want to push the left angle chevron (<) to turn the volume down. However, this brings up the eco-mode menu. Took me longer than I care to admit to figure this out as I kept getting frustrated by the menu. MCServerOwner's snarky advice to read the manual didn't help a lot, as this feature was not well documented in the manual.
