Question Can someone help me get a fix for my issue discovered through latencymon? I tired sfc scan now updated my drivers through driver booster pro.
Jul 27, 2023
_________________________________________________________________________________________________________
CONCLUSION
Your system seems to be having difficulty handling real-time audio and other tasks. You may experience drop outs, clicks or pops due to buffer underruns. One or more DPC routines that belong to a driver running in your system appear
to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:30:21 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DOCSNAP
OS version: Windows 10, 10.0, version 2009, build: 19045 (x64)
Hardware: Z590 AORUS ELITE AX, Gigabyte Technology Co., Ltd.
BIOS: F9
CPU: GenuineIntel 11th Gen Intel(R) Core(TM) i5-11600K @ 3.90GHz
Logical processors: 12
Processor groups: 1
Processor group size: 12
RAM: 32634 MB total
CPU SPEED
Reported CPU speed (WMI): 3912 MHz
Reported CPU speed (registry): 3912 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and
execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 1287.60
Average measured interrupt to process latency (µs): 5.970079
Highest measured interrupt to DPC latency (µs): 1284.10
Average measured interrupt to DPC latency (µs): 2.989055
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 76.332822
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.002812
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.003034
ISR count (execution time <250 µs): 658627
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-1000 µs): 0
ISR count (execution time 1000-2000 µs): 0
ISR count (execution time 2000-4000 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 1154.435072
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 536.67 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.096040
Driver with highest DPC total execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in DPCs (%) 0.241492
DPC count (execution time <250 µs): 5294856
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-10000 µs): 94
DPC count (execution time 1000-2000 µs): 1
DPC count (execution time 2000-4000 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk
while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: none
Total number of hard pagefaults 103820
Hard pagefault count of hardest hit process: 101616
Number of processes hit: 0
PER CPU DATA
CPU 0 Interrupt cycle time (s): 148.872288
CPU 0 ISR highest execution time (µs): 76.332822
CPU 0 ISR total execution time (s): 0.062642
CPU 0 ISR count: 37606
CPU 0 DPC highest execution time (µs): 1154.435072
CPU 0 DPC total execution time (s): 45.037754
CPU 0 DPC count: 4517816
CPU 1 Interrupt cycle time (s): 34.340891
CPU 1 ISR highest execution time (µs): 56.315184
CPU 1 ISR total execution time (s): 0.362195
CPU 1 ISR count: 221041
CPU 1 DPC highest execution time (µs): 230.426380
CPU 1 DPC total execution time (s): 6.227621
CPU 1 DPC count: 239168
CPU 2 Interrupt cycle time (s): 11.614712
CPU 2 ISR highest execution time (µs): 29.638292
CPU 2 ISR total execution time (s): 0.003496
CPU 2 ISR count: 211
CPU 2 DPC highest execution time (µs): 202.554703
CPU 2 DPC total execution time (s): 0.219883
CPU 2 DPC count: 88429
CPU 3 Interrupt cycle time (s): 10.894545
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 201.241053
CPU 3 DPC total execution time (s): 0.062025
CPU 3 DPC count: 24481
CPU 4 Interrupt cycle time (s): 10.657939
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 202.098160
CPU 4 DPC total execution time (s): 0.095453
CPU 4 DPC count: 38076
CPU 5 Interrupt cycle time (s): 10.471944
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 202.197342
CPU 5 DPC total execution time (s): 0.029623
CPU 5 DPC count: 11359
CPU 6 Interrupt cycle time (s): 14.880367
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 205.741309
CPU 6 DPC total execution time (s): 0.407592
CPU 6 DPC count: 157828
CPU 7 Interrupt cycle time (s): 9.61880
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 200.774796
CPU 7 DPC total execution time (s): 0.030194
CPU 7 DPC count: 10407
CPU 8 Interrupt cycle time (s): 14.469167
CPU 8 ISR highest execution time (µs): 60.357873
CPU 8 ISR total execution time (s): 0.234831
CPU 8 ISR count: 399769
CPU 8 DPC highest execution time (µs): 256.203732
CPU 8 DPC total execution time (s): 0.313487
CPU 8 DPC count: 105326
CPU 9 Interrupt cycle time (s): 12.089936
CPU 9 ISR highest execution time (µs): 0.0
CPU 9 ISR total execution time (s): 0.0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 205.122955
CPU 9 DPC total execution time (s): 0.046499
CPU 9 DPC count: 20037
CPU 10 Interrupt cycle time (s): 13.152734
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 199.377556
CPU 10 DPC total execution time (s): 0.228734
CPU 10 DPC count: 67662
CPU 11 Interrupt cycle time (s): 10.803015
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 81.986708
CPU 11 DPC total execution time (s): 0.078819
CPU 11 DPC count: 14362
For one thing, don't use Driver Booster; it's a bloatware software trust me. Used it for 3 years on a gaming PC and ended up getting Trojan Virus in the background. Even though it is a VERY good gamer updating software; it's a scam plus all this info doesn't really help it's kinda meaningless lol. Just uninstall it and move on POG
Whats POG? what i posted is from latencymod just wanted to provide details to anyone so i can have more concise answer.
