Can someone help me? I am getting: Whea uncorrectable error. Not sure whats wrong. Logs inside.
SethLuminous
Can someone help me? I am getting: Whea uncorrectable error, and the PC I am using is pretty new, atleast the RAM, video card, CPU and Motherboard are. I'm sure this is a driver issue, or I hope it is...
Any insight?
Thank you very much.
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffffe001e9e1f028, Address of the WHEA_ERROR_RECORD structure.
Arg3: 00000000b6000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000100153, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
SYSTEM_SKU: SKU
SYSTEM_VERSION: To be filled by O.E.M.
BIOS_DATE: 04/08/2014
BASEBOARD_PRODUCT: SABERTOOTH 990FX R2.0
BASEBOARD_VERSION: Rev 1.xx
DUMP_FILE_ATTRIBUTES: 0x8
Kernel Generated Triage Dump
BUGCHECK_P1: 0
BUGCHECK_P2: ffffe001e9e1f028
BUGCHECK_P3: b6000000
BUGCHECK_P4: 100153
BUGCHECK_STR: 0x124_AuthenticAMD
CPU_COUNT: 8
CPU_MHZ: 126c
CPU_VENDOR: AuthenticAMD
CPU_FAMILY: 15
CPU_MODEL: 2
CPU_STEPPING: 0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: audiodg.exe
CURRENT_IRQL: f
ANALYSIS_VERSION: 10.0.10240.9 amd64fre
STACK_TEXT:
ffffd001`a76b4728 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KeBugCheckEx
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD
DEBUG_FLR_IMAGE_TIMESTAMP: 0
IMAGE_VERSION:
FAILURE_BUCKET_ID: 0x124_AuthenticAMD_PROCESSOR_CACHE
PRIMARY_PROBLEM_CLASS: 0x124_AuthenticAMD_PROCESSOR_CACHE
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0x124_authenticamd_processor_cache
FAILURE_ID_HASH: {b533751b-676e-7546-bcdc-24e6c40d0064}
Followup: MachineOwner
bugcheck 0x124 would not be called from a driver. most likely the audio driver is not at fault.
the CPU called the bugcheck because it got a error from its internal memory controller.
Look at the system up time, if the system uptime is under 15 seconds most likely your system rebooted because of a power issue.
if the uptime is over 15 mins it tends to be a overheating issue.
check the system fans, make sure you don't have any BIOS overclocking or software overclocking of the GPU or CPU.
you can put your memory dump file on a server like microsoft onedrive, mark it public and post a link.
I can take a quick look.
Will do thanks, more issues though posting another log.
Now I am getting this:
ntoskrnl.exe fffff803`cde17000 fffff803`ce669000 0x00852000 0x560ca418 9/30/2015 8:10:16 PM
hal.dll fffff803`ce669000 fffff803`ce6da000 0x00071000 0x55a86499 7/16/2015 7:12:41 PM
kdcom.dll fffff803`cc889000 fffff803`cc894000 0x0000b000 0x559f388f 7/9/2015 8:14:23 PM
mcupdate.dll fffff800`d09e0000 fffff800`d09fd000 0x0001d000 0x559f38be 7/9/2015 8:15:10 PM
werkernel.sys fffff800`d0800000 fffff800`d0810000 0x00010000 0x559f390f 7/9/2015 8:16:31 PM
CLFS.SYS fffff800`d0810000 fffff800`d0874000 0x00064000 0x559f3840 7/9/2015 8:13:04 PM
tm.sys fffff800`d0880000 fffff800`d08a3000 0x00023000 0x559f3834 7/9/2015 8:12:52 PM
PSHED.dll fffff800`d08b0000 fffff800`d08c7000 0x00017000 0x559f3839 7/9/2015 8:12:57 PM Microsoft® Windows® Operating System Platform Specific Hardware Error Driver 10.0.10240.16384 (th1.150709-1700) C:\Windows\system32\PSHED.dll Microsoft Corporation
BOOTVID.dll fffff800`d08d0000 fffff800`d08db000 0x0000b000 0x559f3834 7/9/2015 8:12:52 PM Microsoft® Windows® Operating System VGA Boot Driver 10.0.10240.16384 (th1.150709-1700) C:\Windows\system32\BOOTVID.dll Microsoft Corporation
cmimcext.sys fffff800`d08e0000 fffff800`d08ee000 0x0000e000 0x559f3834 7/9/2015 8:12:52 PM
ntosext.sys fffff800`d08f0000 fffff800`d08fc000 0x0000c000 0x559f3834 7/9/2015 8:12:52 PM
CI.dll fffff800`d0900000 fffff800`d0999000 0x00099000 0x55d55f27 8/19/2015 10:01:27 PM
msrpc.sys fffff800`d1270000 fffff800`d12cc000 0x0005c000 0x559f388f 7/9/2015 8:14:23 PM
FLTMGR.SYS fffff800`d12d0000 fffff800`d1332000 0x00062000 0x559f383f 7/9/2015 8:13:03 PM
ksecdd.sys fffff800`d1340000 fffff800`d1367000 0x00027000 0x559f388b 7/9/2015 8:14:19 PM
clipsp.sys fffff800`d0a00000 fffff800`d0a9c000 0x0009c000 0x559f39a5 7/9/2015 8:19:01 PM
Wdf01000.sys fffff800`d0aa0000 fffff800`d0b7c000 0x000dc000 0x55fa52b2 9/16/2015 10:42:10 PM
WDFLDR.SYS fffff800`d0b80000 fffff800`d0b93000 0x00013000 0x559f3835 7/9/2015 8:12:53 PM
acpiex.sys fffff800`d0ba0000 fffff800`d0bc3000 0x00023000 0x559f38ba 7/9/2015 8:15:06 PM
WppRecorder.sys fffff800`d0bd0000 fffff800`d0bdd000 0x0000d000 0x559f3835 7/9/2015 8:12:53 PM
cng.sys fffff800`d0be0000 fffff800`d0c78000 0x00098000 0x55a866c4 7/16/2015 7:21:56 PM
ACPI.sys fffff800`d0c80000 fffff800`d0d10000 0x00090000 0x55af1117 7/21/2015 8:42:15 PM
WMILIB.SYS fffff800`d0d10000 fffff800`d0d1c000 0x0000c000 0x559f3834 7/9/2015 8:12:52 PM
WindowsTrustedRT.sys fffff800`d0d20000 fffff800`d0d3f000 0x0001f000 0x559f386c 7/9/2015 8:13:48 PM
WindowsTrustedRTProxy.sys fffff800`d0d40000 fffff800`d0d4b000 0x0000b000 0x559f386b 7/9/2015 8:13:47 PM
pcw.sys fffff800`d0d50000 fffff800`d0d62000 0x00012000 0x559f3834 7/9/2015 8:12:52 PM
msisadrv.sys fffff800`d0d70000 fffff800`d0d7b000 0x0000b000 0x559f3a0d 7/9/2015 8:20:45 PM
pci.sys fffff800`d0d80000 fffff800`d0dd5000 0x00055000 0x55a5ba1c 7/14/2015 6:40:44 PM
vdrvroot.sys fffff800`d0de0000 fffff800`d0def000 0x0000f000 0x559f394b 7/9/2015 8:17:31 PM
pdc.sys fffff800`d0df0000 fffff800`d0e0e000 0x0001e000 0x55fa528d 9/16/2015 10:41:33 PM
CEA.sys fffff800`d0e10000 fffff800`d0e29000 0x00019000 0x559f38a5 7/9/2015 8:14:45 PM
partmgr.sys fffff800`d0e30000 fffff800`d0e52000 0x00022000 0x559f383b 7/9/2015 8:12:59 PM
spaceport.sys fffff800`d0e60000 fffff800`d0ed8000 0x00078000 0x559f3a28 7/9/2015 8:21:12 PM
volmgr.sys fffff800`d0ee0000 fffff800`d0ef8000 0x00018000 0x559f383c 7/9/2015 8:13:00 PM
volmgrx.sys fffff800`d0f00000 fffff800`d0f5e000 0x0005e000 0x559f3840 7/9/2015 8:13:04 PM
vmci.sys fffff800`d0f60000 fffff800`d0f79000 0x00019000 0x54091bd4 9/4/2014 7:11:32 PM
vsock.sys fffff800`d0f80000 fffff800`d0f97000 0x00017000 0x54091bf5 9/4/2014 7:12:05 PM
mountmgr.sys fffff800`d0fa0000 fffff800`d0fbd000 0x0001d000 0x55c02a2d 8/3/2015 7:57:49 PM
storahci.sys fffff800`d0fc0000 fffff800`d0fe5000 0x00025000 0x559f3a43 7/9/2015 8:21:39 PM
storport.sys fffff800`d0ff0000 fffff800`d1061000 0x00071000 0x55c9baf6 8/11/2015 2:05:58 AM
EhStorClass.sys fffff800`d1070000 fffff800`d108c000 0x0001c000 0x559f3b69 7/9/2015 8:26:33 PM
fileinfo.sys fffff800`d1090000 fffff800`d10a9000 0x00019000 0x559f38b1 7/9/2015 8:14:57 PM
Wof.sys fffff800`d10b0000 fffff800`d10e8000 0x00038000 0x55c2c2d7 8/5/2015 7:13:43 PM
file_tracker.sys fffff800`d10f0000 fffff800`d113b000 0x0004b000 0x54085fe3 9/4/2014 5:49:39 AM
NTFS.sys fffff800`d19f0000 fffff800`d1c00000 0x00210000 0x55b99edf 7/29/2015 8:49:51 PM
Fs_Rec.sys fffff800`d1400000 fffff800`d140d000 0x0000d000 0x559f3834 7/9/2015 8:12:52 PM
ndis.sys fffff800`d1410000 fffff800`d1536000 0x00126000 0x55fa52f8 9/16/2015 10:43:20 PM
NETIO.SYS fffff800`d1540000 fffff800`d15b6000 0x00076000 0x559f3890 7/9/2015 8:14:24 PM
ksecpkg.sys fffff800`d15c0000 fffff800`d15ed000 0x0002d000 0x559f3994 7/9/2015 8:18:44 PM
tcpip.sys fffff800`d15f0000 fffff800`d184f000 0x0025f000 0x55fa5310 9/16/2015 10:43:44 PM
fwpkclnt.sys fffff800`d1850000 fffff800`d18b6000 0x00066000 0x55fa52e3 9/16/2015 10:42:59 PM
wfplwfs.sys fffff800`d18c0000 fffff800`d18ea000 0x0002a000 0x559f3ab4 7/9/2015 8:23:32 PM
fltsrv.sys fffff800`d18f0000 fffff800`d1913000 0x00023000 0x5461fab1 11/11/2014 5:01:53 AM
fvevol.sys fffff800`d1920000 fffff800`d19bf000 0x0009f000 0x559f38b9 7/9/2015 8:15:05 PM
volsnap.sys fffff800`d1140000 fffff800`d11a0000 0x00060000 0x559f383d 7/9/2015 8:13:01 PM
snapman.sys fffff800`d11a0000 fffff800`d11ed000 0x0004d000 0x54633c4d 11/12/2014 3:54:05 AM
rdyboost.sys fffff800`d11f0000 fffff800`d1234000 0x00044000 0x55c2c2e2 8/5/2015 7:13:54 PM
mup.sys fffff800`d19c0000 fffff800`d19e3000 0x00023000 0x559f38ba 7/9/2015 8:15:06 PM
disk.sys fffff800`d1250000 fffff800`d126e000 0x0001e000 0x559f383b 7/9/2015 8:12:59 PM
CLASSPNP.SYS fffff800`d1370000 fffff800`d13d0000 0x00060000 0x559f383f 7/9/2015 8:13:03 PM
crashdmp.sys fffff800`d09a0000 fffff800`d09b9000 0x00019000 0x559f3a17 7/9/2015 8:20:55 PM
filecrypt.sys fffff800`d2d50000 fffff800`d2d6c000 0x0001c000 0x559f3897 7/9/2015 8:14:31 PM
tbs.sys fffff800`d2d70000 fffff800`d2d7c000 0x0000c000 0x559f38b3 7/9/2015 8:14:59 PM
Null.SYS fffff800`d2d80000 fffff800`d2d8a000 0x0000a000 0x559f3834 7/9/2015 8:12:52 PM
Beep.SYS fffff800`d2d90000 fffff800`d2d9a000 0x0000a000 0x559f3a0a 7/9/2015 8:20:42 PM
BasicDisplay.sys fffff800`d2da0000 fffff800`d2db4000 0x00014000 0x559f390c 7/9/2015 8:16:28 PM
watchdog.sys fffff800`d2dc0000 fffff800`d2dd5000 0x00015000 0x559f390b 7/9/2015 8:16:27 PM
dxgkrnl.sys fffff800`d1e00000 fffff800`d1fe9000 0x001e9000 0x55fa5392 9/16/2015 10:45:54 PM
BasicRender.sys fffff800`d1ff0000 fffff800`d2002000 0x00012000 0x559f3911 7/9/2015 8:16:33 PM
Npfs.SYS fffff800`d2010000 fffff800`d2028000 0x00018000 0x559f3835 7/9/2015 8:12:53 PM
Msfs.SYS fffff800`d2030000 fffff800`d203f000 0x0000f000 0x559f3835 7/9/2015 8:12:53 PM
tdx.sys fffff800`d2040000 fffff800`d2061000 0x00021000 0x559f3889 7/9/2015 8:14:17 PM
TDI.SYS fffff800`d2070000 fffff800`d207f000 0x0000f000 0x559f3888 7/9/2015 8:14:16 PM
ws2ifsl.sys fffff800`d2080000 fffff800`d208d000 0x0000d000 0x559f3aa5 7/9/2015 8:23:17 PM
netbt.sys fffff800`d2090000 fffff800`d20d9000 0x00049000 0x559f3890 7/9/2015 8:14:24 PM
afd.sys fffff800`d20e0000 fffff800`d2172000 0x00092000 0x559f389a 7/9/2015 8:14:34 PM
vwififlt.sys fffff800`d2180000 fffff800`d2199000 0x00019000 0x559f3a71 7/9/2015 8:22:25 PM
pacer.sys fffff800`d21a0000 fffff800`d21cb000 0x0002b000 0x559f3a80 7/9/2015 8:22:40 PM
netbios.sys fffff800`d21d0000 fffff800`d21e2000 0x00012000 0x559f3a77 7/9/2015 8:22:31 PM
rdbss.sys fffff800`d21f0000 fffff800`d2262000 0x00072000 0x559f3b6d 7/9/2015 8:26:37 PM
csc.sys fffff800`d2270000 fffff800`d22fc000 0x0008c000 0x559f3b6a 7/9/2015 8:26:34 PM
zamguard64.sys fffff800`d2300000 fffff800`d2321000 0x00021000 0x55e2fca0 8/30/2015 5:52:48 AM
nsiproxy.sys fffff800`d2330000 fffff800`d2340000 0x00010000 0x559f3893 7/9/2015 8:14:27 PM
npsvctrig.sys fffff800`d2340000 fffff800`d234d000 0x0000d000 0x559f3897 7/9/2015 8:14:31 PM
mssmbios.sys fffff800`d2350000 fffff800`d2360000 0x00010000 0x559f3891 7/9/2015 8:14:25 PM
gpuenergydrv.sys fffff800`d2360000 fffff800`d236a000 0x0000a000 0x559f3bb5 7/9/2015 8:27:49 PM
mbae64.sys fffff800`d2370000 fffff800`d237d780 0x0000d780 0x540df503 9/8/2014 11:27:15 AM
dfsc.sys fffff800`d2380000 fffff800`d23a9000 0x00029000 0x559f3b62 7/9/2015 8:26:26 PM
AntiLog64.sys fffff800`d23d0000 fffff800`d23f0000 0x00020000 0x54a28d95 12/30/2014 4:33:41 AM
ahcache.sys fffff800`d23f0000 fffff800`d242b000 0x0003b000 0x559f3b67 7/9/2015 8:26:31 PM
tib_mounter.sys fffff800`d2430000 fffff800`d246d000 0x0003d000 0x55a8f34e 7/17/2015 5:21:34 AM
tap0901.sys fffff800`d2470000 fffff800`d247d000 0x0000d000 0x521606a1 8/22/2013 5:40:01 AM
vmnetadapter.sys fffff800`d2480000 fffff800`d248a000 0x0000a000 0x53d4fef6 7/27/2014 6:30:30 AM
VMNET.SYS fffff800`d2490000 fffff800`d249b000 0x0000b000 0x53d4fef3 7/27/2014 6:30:27 AM
CompositeBus.sys fffff800`d24a0000 fffff800`d24b1000 0x00011000 0x559f3a0b 7/9/2015 8:20:43 PM
kdnic.sys fffff800`d24c0000 fffff800`d24cd000 0x0000d000 0x559f3a31 7/9/2015 8:21:21 PM
umbus.sys fffff800`d24d0000 fffff800`d24e5000 0x00015000 0x559f3a19 7/9/2015 8:20:57 PM
atikmpag.sys fffff800`d24f0000 fffff800`d2598000 0x000a8000 0x55bfc1e6 8/3/2015 12:32:54 PM
atikmdag.sys fffff800`d4800000 fffff800`d5d0a000 0x0150a000 0x55bfc79c 8/3/2015 12:57:16 PM
HDAudBus.sys fffff800`d5d10000 fffff800`d5d2b000 0x0001b000 0x559f3a57 7/9/2015 8:21:59 PM
portcls.sys fffff800`d5d30000 fffff800`d5d86000 0x00056000 0x55fa54a9 9/16/2015 10:50:33 PM
drmk.sys fffff800`d5d90000 fffff800`d5db1000 0x00021000 0x559f3a3e 7/9/2015 8:21:34 PM
ks.sys fffff800`d4400000 fffff800`d4466000 0x00066000 0x559f3a18 7/9/2015 8:20:56 PM
USBXHCI.SYS fffff800`d4470000 fffff800`d44d0000 0x00060000 0x55d2d74f 8/17/2015 11:57:19 PM
ucx01000.sys fffff800`d44d0000 fffff800`d4508000 0x00038000 0x559f3a57 7/9/2015 8:21:59 PM
usbohci.sys fffff800`d4510000 fffff800`d451f000 0x0000f000 0x559f3a41 7/9/2015 8:21:37 PM
USBPORT.SYS fffff800`d4520000 fffff800`d4596000 0x00076000 0x559f3a42 7/9/2015 8:21:38 PM
usbehci.sys fffff800`d45a0000 fffff800`d45bc000 0x0001c000 0x559f3b76 7/9/2015 8:26:46 PM
serial.sys fffff800`d45c0000 fffff800`d45db000 0x0001b000 0x559f3a12 7/9/2015 8:20:50 PM
serenum.sys fffff800`d45e0000 fffff800`d45ef000 0x0000f000 0x559f3a0a 7/9/2015 8:20:42 PM
rt640x64.sys fffff800`d45f0000 fffff800`d4683000 0x00093000 0x551c01f7 4/1/2015 7:34:31 AM
wmiacpi.sys fffff800`d4690000 fffff800`d469c000 0x0000c000 0x559f38b8 7/9/2015 8:15:04 PM
amdppm.sys fffff800`d46a0000 fffff800`d46c6000 0x00026000 0x559f383b 7/9/2015 8:12:59 PM
NdisVirtualBus.sys fffff800`d4710000 fffff800`d471d000 0x0000d000 0x559f3a7a 7/9/2015 8:22:34 PM
swenum.sys fffff800`d4720000 fffff800`d472c000 0x0000c000 0x559f3a0b 7/9/2015 8:20:43 PM
LGBusEnum.sys fffff800`d4730000 fffff800`d4734e00 0x00004e00 0x553ab3bc 4/24/2015 2:21:00 PM
LGJoyXlCore.sys fffff800`d4740000 fffff800`d474c700 0x0000c700 0x553ab3b9 4/24/2015 2:20:57 PM
rdpbus.sys fffff800`d4750000 fffff800`d475e000 0x0000e000 0x559f3b03 7/9/2015 8:24:51 PM
usbhub.sys fffff800`d4760000 fffff800`d47df000 0x0007f000 0x5604b9df 9/24/2015 8:05:03 PM
USBD.SYS fffff800`d47e0000 fffff800`d47ee000 0x0000e000 0x559f3a12 7/9/2015 8:20:50 PM
UsbHub3.sys fffff800`d25a0000 fffff800`d2624000 0x00084000 0x55fa54a9 9/16/2015 10:50:33 PM
RTKVHD64.sys fffff800`d2630000 fffff800`d2ab2000 0x00482000 0x55800089 6/16/2015 3:55:05 AM
ksthunk.sys fffff800`d47f0000 fffff800`d47fe000 0x0000e000 0x559f3da3 7/9/2015 8:36:03 PM
AtihdWT6.sys fffff800`d5dc0000 fffff800`d5dde000 0x0001e000 0x5563caaf 5/25/2015 6:21:51 PM
usbccgp.sys fffff800`d46d0000 fffff800`d46fb000 0x0002b000 0x559f3a15 7/9/2015 8:20:53 PM
hidusb.sys fffff800`d5de0000 fffff800`d5df1000 0x00011000 0x559f3a1c 7/9/2015 8:21:00 PM
HIDCLASS.SYS fffff800`d2ac0000 fffff800`d2aed000 0x0002d000 0x559f3a21 7/9/2015 8:21:05 PM
HIDPARSE.SYS fffff800`d2af0000 fffff800`d2b01000 0x00011000 0x559f3a18 7/9/2015 8:20:56 PM
kbdhid.sys fffff800`d4700000 fffff800`d4710000 0x00010000 0x559f3a11 7/9/2015 8:20:49 PM
kbdclass.sys fffff800`d2b10000 fffff800`d2b23000 0x00013000 0x559f3a15 7/9/2015 8:20:53 PM
VMkbd.sys fffff800`d2b30000 fffff800`d2b3b000 0x0000b000 0x55ce55fc 8/14/2015 1:56:28 PM
LGSHidFilt.Sys fffff800`d2b40000 fffff800`d2b55000 0x00015000 0x51a76d51 5/30/2013 8:16:33 AM
mouhid.sys fffff800`d2b60000 fffff800`d2b6f000 0x0000f000 0x559f3a14 7/9/2015 8:20:52 PM
mouclass.sys fffff800`d2b70000 fffff800`d2b82000 0x00012000 0x559f3a11 7/9/2015 8:20:49 PM
fastfat.SYS fffff800`d2b90000 fffff800`d2be5000 0x00055000 0x55fa52e6 9/16/2015 10:43:02 PM
dump_storport.sys fffff800`d2c00000 fffff800`d2c0f000 0x0000f000 0x559f3a0e 7/9/2015 8:20:46 PM
dump_storahci.sys fffff800`d2c40000 fffff800`d2c65000 0x00025000 0x559f3a43 7/9/2015 8:21:39 PM
dump_dumpfve.sys fffff800`d2c90000 fffff800`d2caa000 0x0001a000 0x559f3891 7/9/2015 8:14:25 PM
win32k.sys fffff960`f9aa0000 fffff960`f9ac3000 0x00023000 0x559f3900 7/9/2015 8:16:16 PM
win32kfull.sys fffff960`f9400000 fffff960`f9781000 0x00381000 0x5604b8f7 9/24/2015 8:01:11 PM
win32kbase.sys fffff960`f9790000 fffff960`f98ef000 0x0015f000 0x5604b8d6 9/24/2015 8:00:38 PM
dxgmms2.sys fffff800`d2cb0000 fffff800`d2d30000 0x00080000 0x55fa55af 9/16/2015 10:54:55 PM
monitor.sys fffff800`d2d30000 fffff800`d2d40000 0x00010000 0x559f3900 7/9/2015 8:16:16 PM
TSDDD.dll fffff960`f9900000 fffff960`f990a000 0x0000a000 0x559f3b02 7/9/2015 8:24:50 PM
ATMFD.DLL fffff960`f9910000 fffff960`f9970000 0x00060000 0x55dea620 8/26/2015 10:54:40 PM Adobe Type Manager Windows NT OpenType/Type 1 Font Driver 5.1 Build 246 C:\Windows\system32\ATMFD.DLL Adobe Systems Incorporated
cdd.dll fffff960`f9970000 fffff960`f99ac000 0x0003c000 0x559f38ff 7/9/2015 8:16:15 PM
WudfPf.sys fffff800`d2de0000 fffff800`d2dfe000 0x0001e000 0x559f383d 7/9/2015 8:13:01 PM
luafv.sys fffff800`d39f0000 fffff800`d3a16000 0x00026000 0x559f389a 7/9/2015 8:14:34 PM
WUDFRd.sys fffff800`d3a20000 fffff800`d3a5b000 0x0003b000 0x559f3b83 7/9/2015 8:26:59 PM
tib.sys fffff800`d3a60000 fffff800`d3b62000 0x00102000 0x55a8bc57 7/17/2015 1:27:03 AM
storqosflt.sys fffff800`d3b70000 fffff800`d3b85000 0x00015000 0x559f394b 7/9/2015 8:17:31 PM
rdpvideominiport.sys fffff800`d3b90000 fffff800`d3b9d000 0x0000d000 0x559f3868 7/9/2015 8:13:44 PM
rdpdr.sys fffff800`d3ba0000 fffff800`d3bd2000 0x00032000 0x559f3b0a 7/9/2015 8:24:58 PM
WpdUpFltr.sys fffff800`d3be0000 fffff800`d3bed000 0x0000d000 0x559f383b 7/9/2015 8:12:59 PM
bowser.sys fffff800`d3400000 fffff800`d3422000 0x00022000 0x559f38b5 7/9/2015 8:15:01 PM
mrxsmb.sys fffff800`d3430000 fffff800`d34a0000 0x00070000 0x559f3b91 7/9/2015 8:27:13 PM
mrxsmb20.sys fffff800`d34a0000 fffff800`d34de000 0x0003e000 0x559f3bab 7/9/2015 8:27:39 PM
SbieDrv.sys fffff800`d34e0000 fffff800`d3513000 0x00033000 0x56005598 9/21/2015 12:08:08 PM
mslldp.sys fffff800`d3520000 fffff800`d353a000 0x0001a000 0x559f3aa6 7/9/2015 8:23:18 PM
rspndr.sys fffff800`d3540000 fffff800`d355a000 0x0001a000 0x559f3a95 7/9/2015 8:23:01 PM
wanarp.sys fffff800`d3560000 fffff800`d357b000 0x0001b000 0x559f3a7d 7/9/2015 8:22:37 PM
vmnetbridge.sys fffff800`d3580000 fffff800`d3591000 0x00011000 0x53d4fef8 7/27/2014 6:30:32 AM
lltdio.sys fffff800`d35a0000 fffff800`d35b6000 0x00016000 0x559f3a99 7/9/2015 8:23:05 PM
HTTP.sys fffff800`d35c0000 fffff800`d36be000 0x000fe000 0x559f3899 7/9/2015 8:14:33 PM
mpsdrv.sys fffff800`d36c0000 fffff800`d36d9000 0x00019000 0x559f3a95 7/9/2015 8:23:01 PM
vmx86.sys fffff800`d36e0000 fffff800`d36fa000 0x0001a000 0x55ce55fb 8/14/2015 1:56:27 PM
hcmon.sys fffff800`d3700000 fffff800`d3712000 0x00012000 0x55caaef4 8/11/2015 7:27:00 PM
AODDriver2.sys fffff800`d3720000 fffff800`d3752000 0x00032000 0x52fa044c 2/11/2014 4:06:52 AM
HD-Hypervisor-amd64.sys fffff800`d3760000 fffff800`d378a000 0x0002a000 0x55d47160 8/19/2015 5:06:56 AM
lgcoretemp.sys fffff800`d3790000 fffff800`d3798000 0x00008000 0x557719ba 6/9/2015 9:52:10 AM
srvnet.sys fffff800`d37a0000 fffff800`d37e2000 0x00042000 0x559f38dd 7/9/2015 8:15:41 PM
mmcss.sys fffff800`d37f0000 fffff800`d3804000 0x00014000 0x559f383c 7/9/2015 8:13:00 PM
mrxsmb10.sys fffff800`d3810000 fffff800`d385e000 0x0004e000 0x559f3bac 7/9/2015 8:27:40 PM
mbam.sys fffff800`d3860000 fffff800`d386a000 0x0000a000 0x540754e1 9/3/2014 10:50:25 AM
Ndu.sys fffff800`d3870000 fffff800`d3896000 0x00026000 0x559f3a77 7/9/2015 8:22:31 PM
srv2.sys fffff800`d38a0000 fffff800`d394c000 0x000ac000 0x559f3b73 7/9/2015 8:26:43 PM
peauth.sys fffff800`d73d0000 fffff800`d7490000 0x000c0000 0x559f399e 7/9/2015 8:18:54 PM
srv.sys fffff800`d7490000 fffff800`d751c000 0x0008c000 0x559f3b71 7/9/2015 8:26:41 PM
tcpipreg.sys fffff800`d7520000 fffff800`d7534000 0x00014000 0x559f3a70 7/9/2015 8:22:24 PM
vmnetuserif.sys fffff800`d7540000 fffff800`d754a000 0x0000a000 0x55ce52e3 8/14/2015 1:43:15 PM
vstor2-mntapi20-shared.sys fffff800`d7550000 fffff800`d755c000 0x0000c000 0x559efd85 7/9/2015 4:02:29 PM VMware vCenter Converter Standalone VMware Virtual Storage Volume Driver 5.5.3 build-2885114 built by: WinDDK C:\Windows\system32\drivers\vstor2-mntapi20-shared.sys VMware, Inc.
condrv.sys fffff800`d7560000 fffff800`d7571000 0x00011000 0x559f3835 7/9/2015 8:12:53 PM
tunnel.sys fffff800`d7580000 fffff800`d75af000 0x0002f000 0x55b99df2 7/29/2015 8:45:54 PM
