Question Can someone help me in finding a Registry entry ?
Mercian
453
4
19,015
I am using a program called RDBM 24 used for modding EA football games. It has stopped opening and re-installing does not help. When Cheat Engine does this I delete the Reg Entry which solves the problem. I cannot find the entry and Reg-scanner only shows the install info. The program does work as I have tried the same install on a back up Windows on another drive. Can anyone help?
Thanks.
