I live in the UK and have a budget around £1000 to spend. its pretty much all around gaming. i have a 144hz monitor if that is needed for anything, any help is appreciated.
thank you
thank you
i have two 1080p monitors but my main is 144hz, i have all keyboard and mouse ect and windows.What resolution is the monitor? What do you need, do you need Windows, keyboard & mouse or us this just for the tower only?
thanks man! do you reckon this could run AAA games at 60 + fps?, and also it says there are compatibility errors, do i need to change anything if so what?Can look at something like this,
PCPartPicker Part List
CPU: AMD Ryzen 5 3600X 3.8 GHz 6-Core Processor (£188.00 @ Amazon UK)
CPU Cooler: Cooler Master Hyper 212 Black Edition 42 CFM CPU Cooler (£32.99 @ Amazon UK)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard (£89.99 @ Box Limited)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3600 Memory (£62.83 @ CCL Computers)
Storage: Corsair MP510 240 GB M.2-2280 NVME Solid State Drive (£43.99 @ Amazon UK)
Storage: Samsung 860 QVO 1 TB 2.5" Solid State Drive (£82.91 @ Amazon UK)
Video Card: XFX Radeon RX 5700 XT 8 GB THICC II Video Card (£359.99 @ Amazon UK)
Case: Phanteks Eclipse P400A ATX Mid Tower Case (£64.17 @ CCL Computers)
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply (£69.98 @ Amazon UK)
Case Fan: ARCTIC ACFAN00119A 56.3 CFM 120 mm Fan (£4.99 @ Amazon UK)
Total: £999.84
Generated by PCPartPicker 2019-12-28 23:04 GMT+0000
Yes i it will. Can look at reviews about that gpu if you wish.😉thanks man! do you reckon this could run AAA games at 60 + fps?,
The compatibility error is that the B450 motherboards usually don't come with a bios that supports the latest AMD Ryzen cpu's,the MSI Max version however does support these from the get go.and also it says there are compatibility errors, do i need to change anything if so what?
thanks for the help
