Can someone help me plz (problems with motherboard)
khula
well l mistakenly tried to insert a ddr2 stick in a ddr3 dimmslot and that's when l had problems, l only had a 4 gb vengeance ram stick but when l realized that the ddr2 wouldn't fit on a ASUS M4A89GTD PRO/USB3 motherboard l restarted the desktop. The screen wouldn't come on and the dram light kept flashing and sometimes with a stable light while always beeping, when l tried take off the ram stick it needed more force to pull out and l think that damaged the dimm slots. One of the blue on has a raised right side and the second slot has a missing tooth.
So my question is what exactly is causing the dram light to keep beeping and do l need a new motherboard, cause l doubt l can get one.
Latest posts
