I got a corsair 275 r case https://www.corsair.com/ww/en/Categ...es-275R-Mid-Tower-Gaming-Case/p/CC-9011131-WW
i recently got these fans https://vetroo.com/products/aigo-au...tion-rgb-cpu-coolers-radiator-with-controller
as far as i know my case supports 3 120mm fans in the front, 2 120mm on the top. So i mounted the 3 fans to the front where the 3 fans are pushing cool air out. However i at first saw a temperature drop in my hard drives and components alike, after about 4 or 5 hours, my temperature of the hard drives went from 36 to almost 50c, from originally being around 40 without the fans, and my CPU and GPU temperature were at idle higher than normal. And from feeling the fans on the outside there was a lot of hot air inside. I mounted the second oem from corsair fan to the top since i moved it when i installed the 3. The only reason i arranged the 3 fans the way they are is since the RGB is on the inside of the case and my front panel isn't see through, so if i turn them around the rgb wont be as visible. Should i switch them facing the other way?
