Can someone help me with my first build :(
Preator Marwan
24
So im doing my first build and i just wanted to some opinion that might help me since i choosed every part by myself without guides and im afraid i pick some stuff that r incompatible with each other or something =[ so if someone can help me would be so much appreciate
i already have GTX 1060 3gb so gonna add it to this system
https://pcpartpicker.com/list/xkpzWD
I would suggest the RX 580 4gb instead of the 3gb. If you want 1060, go for the 6gb.
Regarding the part list, go for a atx mobo like the msi tomahawk B450.
Try the fractal design focus g case.
Regarding ur hdd port, I assume you have your Microsoft account registered. So take backup format the c drive, and fresh install windows in a USB using media creation tool. U can use Rufus software to create a bootable USB.
You can download the latest win 10 from Microsoft website. Install the necessary drivers too.
A fresh/clean install always helps and will definitely avoid you PITA.
i already have the gtx 1060 3gb so its not a problem rn
about the motherboard i dont know really whats the major difference between atx and micro atx beisde the size and more pcie slots? because im on a budget and the tomahawk kinda expensive for me 🙁
