Hello, my name is Jetsada and I like to know how of these components interact with each other and if its compatible.
Intel core i5 4440 3.1 GHz 4 cores 4 wires 6mb cache LGA 1150 socket.
Gigabyte GA-Z97P-D3 ATX motherboard LGA 1150 z97 USB 3.0 gigabit lan HD audio 8-channel.
Crucial ballistix sport 8 GB (4gbx2) DDR3 (pc3-12800) 240-pin UDIMM memory (RAM)
Gigabyte gaming 2GD Nvidia GeForce GTX 960 2GB graphic card
WD blue 1TB 3.5 inch SATA 6gb/s 7200 RPM hard drive.
Sentey computer gaming case ATX GS-6011 blade Mid tower (slightly smaller according to amazon)
And the last thing: Sentry power supply 725 W- xpp725/computer power supply ATX/140mm Fan sleeve bearing/48 campers/6SATA/2pci-e 6-2/ 115-230 voltage/power cord SLi and crossfire ready.
I really wanna know how all these components interact with each other and if they are compatible for ready to use and build it. Any advice is welcome so I can improve or change it.
I would be very pleased if someone can answer me because i'm new to tom'sHardware and into building my gaming pc soon
