Can the fan wire of smps be cut and joined
sau_gau
i tried to replace the smps fan.for this i cut the wire and tried to connect another fan.but the fan didn't work.......What may be the problem?
moody89
799
Like jsc said they are the main reasons it would not be working. When you cut the wires from the old fan did you cut them one at a time or did you cut them all at the same time?
When you connected the new fan, how did you connect the two ends of the wire? A crimped connection insulated with standard insulation tape is always the best.
