[SOLVED] Can the NZXT H500i fit a G1 GTX1070ti And 240mm AIO Cooler
OilPirate
27
I am considering buying the Corshair H500i case however I have a 3 Fan Gpu Which is the Gigabyte Gtx1070ti and I know this will fit on its own. However In the future I am planing on buying a 240mm AIO cooler to mount at the front of the case and I am concerned that there may not be enough room for the both of them.
A 240 mm radiator can only be mounted at the front of the H500i. Without an aio the case has clearance for a max length gpu of 381mm. Find out the thickness of the aio you want with the fans mounted to it and subtract that from the 381 mm, that will tell you the max length gpu that will fit with the aio installed.
