Can Thermaltake SpinQ VT fit in Thermaltake V9 case?
lgmcben
11
Can this cpu cooler: (depth = 159 mm)
http://thermaltakeusa.com/Product.aspx?C=1405&ID=1904
fit into this case? (depth = 191 mm)
http://thermaltakeusa.com/Product.aspx?C=1390&ID=1819
I'm building a new system to replace my 7 years old PC. I've all the specs in my mind.
Only 2 things left is the case and the cpu cooler. I'm going to order the above two. Anyone know if SpinQ VT fits in V9 case?
Thank you in advance. =)
P.S. If not, please feel free to recommend a cpu cooler + case combination. My criteria is:
- The case should have power supply dust filter. (the V9 has it)
- The cpu cooler should be quiet. The mediocre performance is fine.
- Budget: $200 for case & cpu cooler combined.
The cpu heatsink will not fit in the case.
The Thermaltake V9 case is 7.52 inches wide.
The Thermaltake SpinQ VT is a tower style cpue hatsink that 159mm tall.
Those tall tower style cpu heatsinks require a pc case that is at least 8 inches (204mm) wide and a case that is at least 8.5 inches wide if there is a case fan mounted on the side panel..
Have a look at the Lian Li / Lancool Dragon Lord cases. Th cases meets your requirements. They come in a variety of configurations and prices. Ventilation, airflow, cooling, fan noise, space, and cable management are excellent.
http://www.lancoolpc.com/en/produc [...] s_index=62
Here is a link to a video review of the pc-k60 version made by one of the veteran posters at this forum...
Here is a link to a video review of the pc-k60 version made by one of the veteran posters at this forum:
http://www.youtube.com/watch?v=U2MdUGxWEcU
mwave.com has the lowest prices in the USA:
http://www.mwave.com/mwave/deepsea [...] &ALL=y&TP=
Here is a link to a very good web site with more useful information about cpu heatsinks that will help you make an informed decision:
http://www.frostytech.com/top5heatsinks.cfm
You can use the Google embedded search feature at the web site to find more information about heatsinks for specific cpu sockets.
Personally, I'd recommend the Coolermaster Hyper 212+ cpu heatsink. It is much better than mediocre and represents a good value. If you shop carefully you can sometimes find it onsale for $29.99 in the USA.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065&cm_re=hyper_212%2b-_-35-103-065-_-Product
Here are links to technical reviews:
http://www.google.com/search?hl=en&source=hp&q=cooler+master+hyper+212+plus+review&aq=2&aqi=g10&aql=&oq=cooler+master+hyper+&gs_rfai=
Latest posts
