Can these components fit in to my system
boubipew
12
So im planning on upgrading my computer and i wanna know if these components can fit into it.
I'm planning to buy this psu Corsair VS Series VS550 550W ATX 2.31
And this processor MD Ryzen 5 1500X Wraith Spire CPU - 3.6 GHz - AMD AM4 - 4 ytimet - AMD Boxed (PIB)
And ASUS GeForce GTX 1060 DUAL 3GB graphics card.
And i wanna know if my motherboard can handle these https://www.gigabyte.com/Motherboard/GA-H110M-S2H-DDR3-rev-10#ov
And also i have 8,00 GB ram.
But i just wanna know do i even need to buy that psu my current psu is 350w?
DRagor
Splendid
Jan 23, 2017
6,831
1,755
PSU is low quality but compatible.
CPU is not compatible with your motherboard, it is AMD and your board only takes 6th and 7th gen Intel CPU.
GPU is compatible.
boubipew
12
What would be better psu and processor then?
WildCard999
Champion
Jul 18, 2014
14,461
21
57,415
2,829
Not sure what your budget is but something like this would be better. Also use PCPartpicker as it will suggest the lowest price from good retailers and checks compatibility.
CPU: AMD - Ryzen 5 1400 3.2GHz Quad-Core Processor ($146.99 @ SuperBiiz)
Motherboard: ASRock - Fatal1ty AB350 Gaming K4 ATX AM4 Motherboard ($53.99 @ Newegg)
Video Card: EVGA - GeForce GTX 1060 3GB 3GB SC GAMING Video Card ($189.99 @ Newegg)
Power Supply: Corsair - CX (2017) 450W 80+ Bronze Certified ATX Power Supply ($23.98 @ Newegg)
Total: $414.95
Generated by PCPartPicker 2017-12-08 09:01 EST-0500
If you can fit it into the budget I would suggest the R5 1600 (CPU).
boubipew
12
Graphics card is a bit too expensive in my country atm but if i dont have to change my motherboard would ASUS GeForce GTX 1060 3GB Dual OC,
Intel Kaby Lake i5-7500 LGA1151 3.4GHz 6MB Boxed and CORSAIR PSU VS Series 450W
Be good idea ?
Btw i'm sorry for my bad english and that i'm dumb with computer components xD.
WildCard999
Champion
Jul 18, 2014
14,461
21
57,415
2,829
The 7500 and 1060 3gb would work fine together but you would want to pair it with a B250 motherboard and make sure the memory is DDR4. Also if possible get a better PSU, the Corsair VS series are poor quality.
boubipew
12
Okay, but can they fit into my motherboard and work well?
boubipew
12
Okay thank you, this helped me alot :), have a great day!
Similar threads
