can these parts fit together please help
Zapjack
4
I need help to fit all parts in my new and first pc build I am in aus and I am getting everything from here https://www.pccasegear.com/index.php?main_page=wish_lis... it has everything I am getting here are the components it is built mainly for planetside 2, AUD
Samsung SH-224DB 24x DVDRW OEM
MSI GeForce GTX 970 Gaming 4GB
Intel Core i7 4790
Antec Basiq VP-600P 600W Power Supply
Avexir Blitz 1.1 Gaming Dragon 8GB (2x4GB) DDR3
Microsoft Windows 7 Home Premium 64bit with SP1 OEM
LG 23M45VQ-B 23in Widescreen LED Monitor
Intel 530 Series 120GB SSD
ASRock B85M-PRO3 Motherboard
Western Digital WD Blue WD5000LPVX 500GB
Corsair Carbide SPEC-02 Mid Tower Gaming Case
Tt eSPORTS Level 10 M Hybrid Gaming Mouse
Creative Tactic 3D Rage Wireless Gaming Headset
Razer BlackWidow Expert 2014 Mechanical Gaming Keyboard
and a external 750GB drive
All looks ok, but I have some suggestions:
- Change the psu for a better one. It is not a bad psu, but it gives 30 amps on the 12 volt line, which is very close to the 28 amps your GTX 970 needs.
- Change the motherboard for at least a H97 or ideally a Z97 one. The B85 is not a bad one but it seems a bit odd to get a cheap motherboard on an otherwise high end build. Also it will probably need a BIOS flash before it can boot up that i7 4790. Unless you have an older intel cpu laying around you will not be able to boot up the computer.
Change the 4790 with a Intel Xeon E3 1231 V3. The 200mhz faster isn't worth $66 higher price. It will perform identical to an i7 4770. Change the board to an H97 board, with the savings. SSD, I would change to a Crucial MX100. Change the PSU to an XFX, Seasonic, Evga, or even a better model Antec.
