Can these parts run games maxed out graphics with 60+ fps
Annyeong
22
Tera Rising
ArcheAge
Peria Chronicles
Project Black Sheep
Monster Hunter Online
Kingdom Under Fire 2
Icarus Online
Bless
Blade & Soul
Black Desert Online
Intel Core i5-4460 3.2GHz Quad-Core
Motherboard MSI H97M-E35 Micro ATX LGA1150
Memory Crucial Ballistix Sport XT 8GB (2 x 4GB) DDR3-1600
Storage Western Digital Caviar Blue 1TB 3.5" 7200RPM
Video Card MSI GeForce GTX 970 4GB Twin Frozr V
Case Xigmatek Recon ATX Mid Tower
Power Supply XFX 550W ATX12V / EPS12V
Optical Drive Lite-On iHAS124-04 DVD/CD Writer
Operating System Microsoft Windows 8.1 (OEM) (64-bit)
Please recommend me parts if some of these parts can't run the games above at maxed graphics with 60+fps.
Thanks!
Yup, that's about as good as you can do for a mid-high gaming machine these days. Would agree with the SSD.
I would get the optical drive from Asus/Samsung/LG instead of that Lite-On one; the $2 or so you'd save is not worth it if it breaks.
My bad haha, well you can look at websites from the uk and put the links here i will let you know wich one i would choose. There are so many different ssds who are all pretty much good.
Im not really sure which ones are good... Could you recommend me some on http://uk.pcpartpicker.com/parts/internal-hard-drive/#sort=d7
Thanks!
http://uk.pcpartpicker.com/part/intel-internal-hard-drive-ssdsckgw180a401 i use this one never had any problems. I also have a OCZ agility 3 120 gb works fine no problems been running for 3+ years.
Thanks for the help!
But its not compatible for some reason....
http://uk.pcpartpicker.com/parts/partlist/#incompatibilities
Nope your all good to go!(make sure you have cables) If this helped you out make sure you pick a "'best answer" :)
