Fishikaint :
But i have a 6300 and a GTX 770, is this for BF4 or QArma 3?
Sorry, should've specified this is BF4. I don't have Arma 3. Plus I rarely play BF4 which is why I had to actually launch game to get you some numbers.
I have a 8350 and dual gtx 770's. I disabled sli profile so only ran one 770. Yes mine is higher cpu than yours. But its still pretty close, given 6 vs 8 core and we share the same graphics card it is/should be pretty close.
I gave playable ultra quality frames, but will stress that it does dip quite a bit, and makes for less than ideal gameplay. Since when its heavy graphics load like when your actually in the middle of big firefight, then things get glitch. Not the time of play id want to be less than 100%. Yet when running around its more than fine, yet again idk when im running its more like when im dying or killing that I want high numbers. haha.
But i'd recommend high settings, which is also what I play, and still looks great. As said, im more performance than quality.
Arma, I have no clue. But don't see why you couldn't get high settings out of that.
You've, from what I can see, have a great budget setup. Next things I would consider if that were my build: #1 256gb ssd, it just speeds everything up, wont help gaming but anything/everything else like night and day ($100-130). #2 get like a corsair H 100i/105/110 and overclock your chip, you should be able to get 4.0/4.2 on stock volts maybe 4.4ghz. I wouldn't recommend going crazy as then you need more volts means more heat and more wear and tear. ($80-100). After that, nothings worthwhile performance to budget. So play for a good 2-4-6 years (don't know what the future holds), and when its time to upgrade, just start new. As gpu would be first thing to upgrade (years down the road) and im guessing whatever you upgraded to would be limited by your cpu. In which you'd be better off new mobo and cpu since im sure a 8350 will be same boat as yours and get whatever you can afford then. But that's all years from now. SSD and better cooler, maybe a better case if you don't like yours. But those are just worthwhile upgrades when/if you get a chance (not a necessity, but you'll love ssd performance, and overclocked cpu wil get better single core performance and probably net 5-20 fps more). Everything you've got is golden, those are just my tweaks I would do if/when.
Hope this helps.
