Heat rises. When left alone. It's the entire thought behind rear exhaust fans, they are a dinosaur idea leftover from the old AT towers and pre-built pc's that had a solid top. Heat goes up and collects at the top. When a fan blade moves, it displaces air creating a vacuum. Nature abhors a vacuum, so fills the void with the nearest local air, which at the top of those cases was kinda warm. The result was the next blade creating a vacuum again, the byproduct being the original warm block of air being pushed out the back. Rinse and repeat. The only coolers that now benefit well from rear exhaust are towers where the cpu exhaust is aimed directly at the rear exhaust fan. For any other air cooling, majority of that heat is still going up, most rising up and out the top vents. The addition of another 200mm Fan up top at slow rpm will just add to the upwards movement, hastening that heated air out.
You don't need gale force winds in the case, only need enough to keep the airflow moving up and out. In cases where a rear exhaust is used, having another fan nearby doesn't 'steal air' it just adds to the low pressure area, the vacuum, so you end up with a stronger flow from low front to high rear corners. With a 120mm rear and 140mm top rear, you basically duplicate what a single top 200mm is doing.
Intakes aren't for pushing air in, intakes are there to enable the replenishment of the exhausts vacuum with cooler air at higher efficiency. Relying on natural process takes too long, the air has too much chance to heat up and isn't exhausted fast enough, so case temps rise, lowering the efficiency of any heatsink, which allows its heat to rise. Intakes speed up the process, so the generated heat is moved out faster, replaced faster and case temps are lower.
