GandCrab 5.0.3 ransomware infected my pc now i have removed it in safemode but my pictures and other files are encrypted, so i need to know is decrypting is possible or not?
How did you remove the Gandcrab 5.0.3 ransomware ?
Its hard i can say, you can wait for someone to make the decrypting software for it, but that might take months ,year....
I can only suggest, use antivirus or dont go to sketchy sites or download sketchy stuff, always use Virtual Machine for that if you like to do what you like to do.
an app called malwarebytes
any luck with decrypting ? i'm facing the same issue 🙁
Im having the same problem with GandCrab 5.0.3. The only tool i found was bitdefender gandcrab decryptor, but its not working. I only get the message Initialization FAILED! at the end of search. Anyone found a working decryptor? Thanks.
