Can we fit a MasterCase 5 tempered glass side panel on a MasterBox 5?
BluStormX
Commendable
Oct 20, 2016
22
Hi,
Can someone please tell me the dimensions of the Cooler Master Mastercase 5 tempered glass side panel?
I was wondering if that can fit on a Masterbox 5 case.
Dimensions for the Masterbox 5 side panel is L 45cm (17 6/8 in) x W 42.9cm (16 7/8 in).
Thanks in advance!
Actually, if you check the tempered glass panels just fixes with the swivel lock to the case.
The four corner screws that are visible, only holds the metal bracing to the glass.
So, if the dimensions are identical, it would ideally fit.
