can we make USB(male both side) cable using 2 USB OTG cable ?
hari2202
187
i have 2 otg cable which has male connector at one end .... i like o transfer files between two pcs .. so can i use these two otg cables to make usb cable with male connector at both ends ?
will it work ?
sure if you want to blow things up
computers are hosts, devices are simply devices
its like pluging in a usb webcam to a usb webcam - they wont talk, the device needs a controller host
however there are usb transfer cables out there - they are mostly rubbish
setup a home network with file/printer sharing or use an external hdd/usb pen drive instead - much easier
i have 300 gigs of data . my pendrive is 8 gb only ..
