Question Can we run out PC only with heatsink and no fan for a few minuite?
Jun 27, 2019
50
I know its a very silly question but it had a very old motherboard which have square shaped fan whose wire has been cut by rats and i have to check if the motherboard is working or not? I have to just check its booting or not.
13thmonkey
Keyword here is old: Tom's actually tested this in an interesting video back in the day. PIII locks up but is undamaged, PIV and later can slow to as low as 200MHz and if that is still insufficient will lock up with no damage, Athlon XP burns completely up.
Oh, and hantavirus is worse than Wells.
That's with no HS at all, i'm reading this as HS but no working fan, the lump of metal will keep a lid on it for a very little while.
Even an Athlon would survive that for a long time, if the OP is worried about it, they could just keep a finger on the heatsink the whole time. When the temperature gets unbearable, then it's time to yank the plug.
But all OP probably needs is a fan, not a whole cooler--particularly because they described it as square. Those come in standard sizes of 60mm, 80mm, 92mm etc so they would only need to make sure the plug is the same.
Nov 10, 2018
21
How bad are the wires? Could you not just strip them back a little and twist them together as a very temporary solution?
