Question Can you check this parts lists for any compatability issues
D
Deleted member 362816
Guest
I'd go with the corsair RM850x over that EVGA unit. Otherwise looks fine. Any reason why you like that motherboard. Very overpriced for what it is.
D
Guest
I going to assume video editing etc. Otherwise that CPU is pointless. I guess let us know what you plan to use this PC for and what resolution your monitor is etc.
Reactions: Why_Me
D
Guest
Any particular reason for two 2TB M.2 SSD's? Normally you have a 500GB SSD for your O/S and a 2TB SSD for your storage.
I am lost on this comment?
Pretty sure the "normal" is what you can afford :p
D
Guest
The reason for the separate O/S SSD is in case you have to reformat you don't lose all your stuff but tbh I'm in the pro single 2TB SSD + B660M group myself. :)
Fair enough. Multiple drives always stressed me out for some weird reason haha. But you make a 100% valid point if you have a OS issue etc.
Reactions: Why_Me
Phaaze88
Ambassador
Yeah, stuff happens, and if you have to format or reinstall Windows on the C drive for any reason, it'll go more smoothly if the OS is on the drive by itself - excluding the programs that force themselves on the C drive, but those are easy enough to deal with.
500GB is enough for OS only.
Reactions: Why_Me
Why_Me
Champion
Assuming this build is meant for gaming then we're going to set the OP up right.
O/S SSD
https://www.amazon.com/PNY-CS2130-Internal-Solid-State/dp/B0869BW8MH
PNY CS2130 500GB M.2 PCIe NVMe Gen3 x4 Internal SSD $49.99
Storage SSD
https://www.amazon.com/PNY-CS2130-Internal-Solid-State/dp/B0869C35V2/
PNY CS2130 2TB M.2 PCIe NVMe Gen3 x4 Internal SSD $139.99
CPU cooler
https://www.amazon.com/DeepCool-AK620-High-Performance-Dual-Tower-Dissipation/dp/B09CSXS3X4
DeepCool AK620 CPU Cooler $64.99
https://www.tomshardware.com/reviews/deepcool-ak620-review
https://global.deepcool.com/products/Cooling/cpuaircoolers/AK620-High-Performance-CPU-Cooler/2021/13067.shtml
or ...
https://www.amazon.com/Scythe-Cooler-LGA1700-LGA1151-Towers/dp/B09NZGH4RD
Scythe Fuma 2 Rev.B CPU Cooler $65.99
https://www.scytheus.com/fuma2-rev-b
Here's a decent deal on an Intel 12 gen board.
https://www.amazon.com/ASUS-TUF-H670-PRO-D4-Motherboard/dp/B09NWFPC34
ASUS TUF Gaming H670-PRO WiFi D4 $220.99
https://www.amazon.com/dp/B09NPJDPVG
Intel Core i7-12700F $312.96
https://ark.intel.com/content/www/us/en/ark/products/134592/intel-core-i712700f-processor-25m-cache-up-to-4-90-ghz.html
i7 12700 / 12700F gaming benchmarks.
With the money saved step up to an RTX 3080 Ti 12GB.
https://www.newegg.com/gigabyte-geforce-rtx-3080-ti-gv-n308tgaming-oc-12gd/p/N82E16814932436
GIGABYTE GeForce RTX 3080 Ti OC 12GB Video Card $1,003.99 + $104 off w/ promo code W3BBV24G5, limited offer
https://www.amazon.com/EVGA-Supernova-Modular-Warranty-220-G6-0850-X1/dp/B099821FWG
EVGA SuperNOVA 850 G6 850W 80+ GOLD Modular Power Supply $104.99
Zerk2012
Ambassador
https://pcpartpicker.com/list/9yFn9r an adjusted list based on suggestions ignore the first 2tb ssd i meant to switch with the PNY CS2130 2TB
250 Bucks for a B550 board No way for me and no way I buy a NZXT board.
I would debate a lot of the choices depending on the exact program used and the resolution of the video editing.
If your making money video editing where time is money and just a novice editor is 2 different things.
