S shaun88 Distinguished Dec 3, 2012 279 0 18,790 Apr 21, 2014 #1 the back of my PC is strict and only allows a 80mm fan, I've been looking at water cooling such as Corsair H50 or the H55 but they come with a 120mm fan, I cant seem to find any with 80mm fan please help
Solution faalin Apr 21, 2014 you will have to go to a custom loop or buy a reducing shroud to go from 120mm to 80mm those will be your only option to use an 80mm fan.
faalin Illustrious Feb 22, 2012 6,388 518 41,740 Apr 21, 2014 Solution #2 you will have to go to a custom loop or buy a reducing shroud to go from 120mm to 80mm those will be your only option to use an 80mm fan. Upvote 0 Downvote Solution
