can you help me build a pc? (for playing gtav,fortnite,and bf1)
k3v1ngutierrez
7
I need some one with better knowledge of computer components than me to give me parts to build a pc around the range of 600-700 dollars (something with a 1060. what I am looking to buy right now is something like this but if you have something better please tell me, ...... gtx1060 6gb , i3 8th gen 8100 ,msi z370 -A pro, 8gb ddr4 3200, and a 500w psu
Aug 27, 2018
8
4
Something like this would be great. https://pcpartpicker.com/list/WB24ZR Need a little better CPU to run BF1. Everything else you posted was pretty good. The GPU doesn't need to be that great but it definitely helps if you have the money. Fortnite can be tough on the CPU as well. If you need more help, the website canyourunit will tell you what parts you need to be able to run the game vs parts to play it on the highest settings. You could also go a bit cheaper if you get an AMD processor such as the new AMD Ryzens although I haven't tested those so I am afraid to recommend them since I have an Intel chipset.
Similar threads
Latest posts
