i7 920 @ 3.42 (Did not increase CPU voltage. Just bus speed from 133 to 163 if this matters at all.)
Coolermaster HAF 932
Thermalright Ultra-120 with a Scythe S-Flex fan
Room temp ~75f
Asus P6T Deluxe V2 Bios. Speedstep enabled. Turbo fans enabled for both CPU & ChassisX3. (supposed to boost fan speeds when temps get higher)
Everest IDLE results:
Core1 = 42c
Core2 = 42c
Core3 = 38c
Core4 = 38c
CPU = 31c
Everest LOAD results: (10m of Prime95 blending test)
Core1 = 71c
Core2 = 71c
Core3 = 70c
Core4 = 70c
CPU = 61c
These temps seem awfully high. As I said, I have the turbo fan speed enabled for the CPU and the 3 chassis fans bios listed. However, during my testing the temps either didn't go high enough to enable the fan changes or something with the bios turbo controller is in-op because the RPMs stayed the same. It seems I have no ability to change the fan speed manually in bios either.
Fan speeds: (constant)
CPU = ~1560RPM
Ch1 = ~740RPM
Ch2 = ~775RPM
Ch3 = ~1110RPM
Any suggestions? I've been reading posts about these issues ever since I built this PC a week ago. It's really hard to use another person's issues though because temps seem to change sporadically depending on chipset and system build (some people report low 20s CPU temp but 40-50s core temps at idle) One post is in agreement that 70c CPU temp is ok, another says anything over ~65c is bad. Some refuse to distinguish between core and CPU temps >< All that considered, I chose to make my own special post.
Do I need to re-seat my HS and do a better job with the paste?
Room temp ~75f
Core1 = 42c
Core2 = 42c
Core3 = 38c
Core4 = 38c
CPU = 31c
Core1 = 71c
Core2 = 71c
Core3 = 70c
Core4 = 70c
CPU = 61c
CPU = ~1560RPM
Ch1 = ~740RPM
Ch2 = ~775RPM
Ch3 = ~1110RPM
