Question Can you recommend me a Graphics Card for my old DQ77MK motherboard?
Jul 2, 2022
5
Hi all,
I have an old Base Unit that performs perfectly adequately for my tasks, BUT I am addicted to the old MS Age of Empires games. Unfortunately, it refuses to play V3 of this game citing that I have a 500mb card and it needs 1gb minimum.
Could someone please help me eke out a bit more life from this PC without spending too much. Recommend me a decent card that can hit and exceed the requirement on this system, perhaps into the next two years, without having to get bogged down upgrading anything else?
SYSTEM:
DQ77MK
Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz (8 CPUs), ~3.4GHz
AMD Radeon HD 5450, Display Memory: 4338 MB, Dedicated Memory: 498 MB, Shared Memory: 3840 MB, Current Mode: 1920 x 1080 (32 bit) (60Hz), 16384MB RAM, I use HDMI output.
DirectX Version: DirectX 12
Available OS Memory: 16198MB RAM
Windows 10 64
I suspect this is a straightforward issue, but I am way out of touch now.
Regards
U
Hi all,
SYSTEM:
DQ77MK
Windows 10 64
Regards
U
using a 1050ti with my i7-2600K, it's a cpu slightly weaker than your cpu. The 1050ti works fine playing most PS4 games I feed to it.
1050ti should work fine for your i7-3770k.
if you can't get a 1050ti, a GTX 1650 should work fine too.
____
and in the scenario that you can't get a 1050ti or 1650...
a GT 1030 (GDDR5 version) should work as well, and it's cheap. But be warned, this gpu is weaker than the other two I've mentioned. Only get this if your budget is really limited, or if your power supply cannot handle anything stronger.
View: https://youtu.be/a80mtoQklSo
Reactions: udhi
